There has been a new development. I went on a longer than normal drive, so the sound was happening pretty good by the time I arrived home. I also happened to have someone around to help me.
Again, it's difficult to pinpoint because the sound reverberates throughout all the suspension components, but it really seems as though it is coming from the outer tie rod at the ball joint. I'm very surprised about this, because as I mentioned above, the ball joint feels tight and the boot is intact. The ball joint has a grease fitting, and when I greased it, the old grease that was pushed out looked fine.
In any case, if it really is the tie rod end, it looks like a relatively easy fix. Going to replace it at the weekend and see if that takes care of it.
