nope, just my "husky" self. Maybe a lot of weight is shifting forward since the back end is still a little high. I won't worry about it now that its notched. Rear upper control arm ball joint is bad, so now I gotta decide on doing the bushings and ball joint or just buy the whole assy, which would be a lot easier.....
Weight transfer is a possibility I suppose, but still...
Even KJ's running ARB front bumpers don't often have contact between UCA ball joints and the bumpstops. I think you have more research in your future :waytogo:
As for the rear tri-link, you may have good fortune pressing in new bushings and ball joint but take a good look at the unit and inspect for corrosion. If there's anything past surface rust - and since you live in sandy, salt water Florida it will probably be worse than that - be prepared to replace the entire unit. Frankly it's much easier that R&Ring the unit and the bushings/ball joint.
