Daystar Spacer Dimensions....
MarkMatters
ARizona.
well then I'm just gonna go with that setup then...daystar plates it is...thanks for the inputs...really appreciate it..
MarkMatters
ARizona.
aren't they a "must" when using the 3/4 in spacers to create the fake frankenlift?
MarkMatters
ARizona.
Right. But they're a must must? Or just if you want to must? Will It work w/o them?
coloradored
Colorado
so as i here it since im trying to build a lift, the daystart just takes some of the load off the struts and springs so u can put a poly spacer inside of the hole assembly just like the frankinlift and the rustys steal spacers just work more like a shim!
Atrus
Metro Detroit, MI
I have the Rusty's front spacer lift on right now. 20k miles, no issues. Between 1.5" and 1.75" of lift.
