Definitely i will lift it
Well then use only OME springs with either bilstein or ome shocks
we can provide numbers for everything
the above is proven over the years to be the best available now
Personally I have done over 60 Liberty lifts using OME springs and either bilstein or OME shocks, not including any of my 3
next KKs front are pretty much the same using the same springs, shocks, bumpstops etc as the KJ
Rear is where it changes, same shocks but different springs
Now the kicker comes into the KK using a rear trac bar, something the KJ does not
As you lift the rear of the KK, it pulls the body over to one side, the higher you go the more it pulls it over
so a longer trac bar is needed
JBA used to make thses but no longer does sadly
so have to find a fabricator or ??/
Also it is wise to use extended sway bar links since with a lift the stock ones tend to pull the rear down and not provide full performance
lfhoward can chime in on this since he has first hand knowledge of it ( well its something we both learned on his )
The KJs do not have a rear trac Bar plus no sway bar issues
