Mytmouse
As quoted from a post/thread from JeepCoMJ "KJ snowplow"
"""I'm not asking your opinion on "oh, that's gonna be rough on the vehicle". Yes, it is. but not as rough as you guys who don't plow at all, or only plow commercial think.
The plow will come off when not in use. I do not drive with the plow on, except maybe to the gas station in the middle of a snowstorm when i've just made a quick pass on the driveway while it's still snowing.
My application is residential, private owner for my own driveway and a couple of neighbors, and elderly, when their normal guys are busy with a huge snow.
This is one of those threads that could get a bit upsetting. Just giving you fair warning, if you don't think it's a good idea to put a plow on one, I would prefer that you don't post at all, because you don't know how I run a plow (not hard like a "pro"), and you probably haven't got any or much experience with a plow anyways."""
I'm just starting a new thread for advice on trans cooling.
. I had an old Ford Escape, just wasn't cutting it, so I purposely went looking for another compact small SUV and the Jeep Liberty KJ fit the bill.
I started another post "New to Jeep KJ". I too contemplating/plan to replace the springs with CRD springs. But I also had concerns with the trans cooling..
From other thread;
Ok, after getting the necessary info. for maintenance/service on this "New to me" 05 Liberty (just need to verify front diff fluid weight). A big THANK YOU TO ALL!
As mentioned, I plan on using this Liberty for driveway snow plowing with my Myers Home plow. Not for towing. (I have a BIG Ford F350 7.3 diesel for that). I've been thinking about the trans. temp. I don't plan on doing any towing in the hot summer, just plowing in the cold winter months with it...
This Liberty did not come with the tow package, I was simply going to add an external Delare transmission cooler to it (from etrailers), but as I'm looking around I see it already has an external cooler in front of the rad. Thinking maybe,, or maybe not, good enough, I then decided to search on this forum what others have done, and oh boy, I came across alot of info., people wanting to add for towing and overheating issues.
So from what I'm gathering I can;
Either to add the HD cooling, missing from the tow package, (which I believe is changing ? the electric fan and shroud and adding the mechanical fan with clutch) . But I loose that nice space to get to the oil filter & such ,, oh well...
-And /or- change the rad to an 02 Liberty rad (that has the internal trans cooler along WITH plumbing the original extrenal trans cooler).
I'm a bit confused now. I've read there's choices of fans (I have the 3 wire plug to my fan), and getting the correct clutch, ect. Any help/guidance is appreciated. Also if I got it right about the HD cooling (involving changing the electric fan, ect.). If any of you can simplify this for me/my needs, and if POSSIBLE to include part numbers of what I REALLY NEED? PLEASE
See link for pictures:
https://photos.app.goo.gl/LmBEZjhywSqWcx1d7
I'm thinkg/ leaning towards just adding the HD cooling (fans/shroud/clutch)... That should pull in the necessary cool ambient air pass the existiing external cooler and rad. at the low speeds of plowing for my situation.
From other thread;
