engine from 02 to a 04
groundedracer
i have a 02 liberty with the 3.7L but the engine is blown and I cant seem to find one but I found a bunch for 2004 what would I have to do to use the 04 engine thanks
04Liberty
MD
Same engine basically, just transfer your accessories, sensors, etc.
k99jk99j
ohio
they changed the reluctor wheel (on the crank) at some point! you have to get the right motor with the right reluctor wheel. i believe it changed in 04? mike
jnaut
Seattle
Won't it matter that he probably has a 45RFE transmission? Also what about programming the computer for that?
I'd keep looking for one from a KJ with the 45RFE to be safe.
Or, swap in a CRD engine/******/programming... :D
groundedracer
not sure what were doing with the old engine it is my cuzs jeep I am just doinig it for them at my shop I am guessing that I just need to swap the sensors from the 02 onto the new engine but want to check as the 04 engine is 550 and the cheapest 02 around me is 1800 with 135k on it
the old engine isnt bown yet just making some noise and it has 185k on it they want a new one in stead of fixing this one idk not my car
sleeve
Woodward Ave
Why not remove / rebuild and reinstall the esisting engine in the KJ? You'll get a motor with 0 miles on it again and probably end up with a small warranty in the process..?
You'll have to find a 2002 block or reuse yours as far as I know.
ShafferNY
Ticonderoga, NY
Why won't an '04 3.7 bolt up to a 45RFE? Did Jeep change the bolt pattern the bell housing bolts up to when they went from the 45RFE to the 42RLE?
ShafferNY
Ticonderoga, NY
Okay. I'm drawing a blank. Spline count on what?
Flywheel bolts to the crank, torque converter bolts to the flywheel, transmission engages with the torque converter.
kb0nly
Planet Earth
I'm scratching my head on that one also.. Especially the "ITBJRC" What???
kb0nly
Planet Earth
Also considering the 03' model year came with either of the trans i'm sure they didn't change the bolt pattern of the bell housing or on the block, they should be interchangeable in that sense.
