Firefighterf18
- Joined
- Sep 27, 2021
- Messages
- 13
- Reaction score
- 3
Good afternoon,
I'm in the need of some help. I got a 02 liberty with 3.7 that has a skip when it feels like it. On cylinder 2. Once it starts to skip you cycle the key and start it up ans skip it gone.
I have replace the pistons and rings. 150 psi on all cylinders
Replace heads
Coil packs
Injectors
Swap ecm
Change fuel filter
Change spark plugs
I'm at a lost here. I check for coolant getting into the cylinder
What else do yall think I need to check? Thanks
Replace heads
Coil packs
Injectors
Swap ecm
Change fuel filter
Change spark plugs
