error codes
tpd310228
Fort Campbell, KY
i have an '04 renegade. i looked at 112 pages of stuff on here in the last couple hours. i havent been able to find out how to get these codes : / could someone help me out
LaneKJ
USA
Put your key in the ignition. Turn the key from the "off" position to "on" position 3 times without starting the Jeep, ending with the key in the on position. Codes should pop up on your odometer.
LaneKJ
USA
And if you did it right and nothing pops up, your good!
tpd310228
Fort Campbell, KY
these are the problems with my libby. the speedometer doesnt work, all the fuses are good i tested them today and replace them with the correct fuses. and my front cig lighter doesnt work, idk. these are the error codes i got at work today while sitting in my car instead of going to the motor pool (brainstorming the next projects to do lol got a list of about 30 different things to work on) here's the codes: 0501 and 0137
Snail Farmer
Fairmont, MN
The check engine light is most likely due to the P0137. That code is for the post cat O2 sensor. Not a huge concern as it will not affect engine performance at all. The P0501 is for the speed control sensor. A quick search on the net came up with this. Hope it helps:
Vehicle Application: 2004 Jeep Liberty Sport 3.7L
Customer Concern: No speedometer or odometer operation. Sets code P0501.
Tests/Procedures: 1. Using a compatible scan tool, check the vehicle speed signal in the Body Control Module (BCM) and Powertrain Control Module (PCM). If differences are seen, check the Light Green/Yellow signal wire between the controllers, the PCM puts out a 5v to the BCM and it pulses it to ground.
2. Check the signal wires to the BCM, the Pink/Orange is the supply to the sensor and the Dark Green/Orange is the signal wire.
Potential Causes: Body Control Module (BCM)
Instrument Cluster (IC)
Rear Wheel Speed Sensor
Wiring Harness
Tech Tips: If the vehicle is not equipped with ABS brakes, the speed sensor is wired directly to the BCM. Test for battery voltage on the Yellow wire to the speed sensor. This voltage comes from the BCM. The other wire is the signal wire and should have a square wave signal, with the vehicle moving.
Diagnostic Codes: P0501
Porkchop
Troy Mi
How bought checking the wire harness over the rear diff first seams to be some what of a common fault and easy to check.
tpd310228
Fort Campbell, KY
are you able to get a pic of this? im kinda....slow... when it comes to this mechanical stuff haha. everything i've done to my jeep is learning as i go, learning from mistakes and learning from these forums ;)
Porkchop
Troy Mi
To late to go out and take a pic now but if you get under the rear of your Jeep look on top of the the big pig in the middle of your rear axle follow the only wire harness that goes to it and check the wires and plug.
Hope this helps as something to check maybe someone else has a pic.
J33pfxGl
New York
I got a code of P0113 last night out of the blue on my 2005 Liberty. Any ideas on why?
Luke
Interloper
Bancroft, Canada
P0133 is O2 sensor Bank 1 Sensor 1 (ie drivers side - pre cat). Most likely need a new O2 sensor. Unfortunately that one is a *^&$^* to reach.
Good Luck!
J33pfxGl
New York
Thanks Luke,
I will try it. Hopefully it works!
Ps I have the Dark Khaki Liberty too...best color!
frekeyguy
brampton, ontario
sorry to thread hi-jack. So I tried this earlier this afternoon. After cycling the ignition....i get a message which says "DONE" then it seems to flash every 3-5 seconds.
No codes came up.
Luke
Interloper
Bancroft, Canada
It's just tellin you it has performed the check and has no codes to give you ... or it has given you the last code in sequence.. Hooray!
bluzchk66
Connecticut
Hi there...I have NO idea how to start a new thread here..have looked and looked but can't find the new post place....I came up with engine codes P0839, p0740 and p0706...auto mechanic says it needs a new ****** but I am having my doubts....anybody else out there deal with this? Its an 04 Jeep Liberty Columbia edition with 162k on it...Thanks for your help!
