What brand is the bearing and what brand is the sensor?
I just tried to do my own alignment because the shop cant see me til monday and i have a trip planned for the weekend and this keeps happening, Traction control and ESP/BAS. I thought it looked straight! She measured straight!Exactly which lights are you getting? All three?
Traction Control (Vehicle with squiggly lines)
ABS
ESP/BAS
We need to know which lights you are getting. If it's just Traction Control and ESP/BAS, then you likely just need an alignment. Been there and done that.
If the ABS light is on as well... then.... the problem is deeper than just that.
If you are getting those lights all the time, not just on tight turns, you may have an electrical problem, like a dead wheel speed sensor or frayed wiring going to one. Do you also have the abs light on too? If the traction control only comes on when turning or driving over bumps, that could be an alignment issue.I just tried to do my own alignment because the shop cant see me til monday and i have a trip planned for the weekend and this keeps happening, Traction control and ESP/BAS. I thought it looked straight! She measured straight!
It only happens when turning. I tried to do my own alignment just to get me through the weekend but i may have made it worse. There was no light issue before i touched it. I was just trying to fix the pull to the right. I ****** it up and just need a reliable shop recommendation.If you are getting those lights all the time, not just on tight turns, you may have an electrical problem, like a dead wheel speed sensor or frayed wiring going to one. Do you also have the abs light on too? If the traction control only comes on when turning or driving over bumps, that could be an alignment issue.
Makes sense. Hope you find a good shop to fix it! Do you have JBA UCA'S?It only happens when turning. I tried to do my own alignment just to get me through the weekend but i may have made it worse. There was no light issue before i touched it. I was just trying to fix the pull to the right. I ****** it up and just need a reliable shop recommendation.
