Hi All,
I have just got an EVIC to fit to my 07 Sport upgrade (Factory leather) and would like some clarity on the TPMS saga.
I Have Temp, AVG Fuel, Compass, Distance to empty, Time Etc and can also access some other settings.
On the down side No TPMS. I have been doing a lot of research on this and I believe it can be narrowed done to two possibilities.
Keep in mind the EVICS for 06-07's are dumb terminals - they only display what they are told by the BCM.
I do have the tire pressure warning light as most later model sports do.
Ok so why no TPMS - the EVIC is compatible for sure - it came from a 06 limited from the which im sure did have TPMS!
Here my assumptions from what I have read so far.
1) My Sport physically does not have the proper components or electronics installed. It may be I need a Limited BCM or different wheel sensors or both - I am not sure at this point and any help in answering this would be appreciated. I would be very interested to know however if the tire pressure senor part numbers are the same on the limiteds and sports on the Export models - can someone find this out?? My 07 Sport is this upgrade with the leather and stacker etc.
2) The setting in the BCM to display PSI tire pressure is not switched on. If this is the case all I need is to get in there with and enhanced scan tool and fool around a little and switch it on - or I could just take it to the dealer and ask them to do it! This would be the preferred option.
I also noticed that in the to upgrade to a TPMS it only costs like $70.00 Extra from when you buy it new. This has got me thinking it may be as simple as changing a setting in the BCM.
All in all, its going to cost me lots of money to get the proper gear Or, its just a BCM setting.
I know the older models where different, however I just want to focus on the 06 and 07's here, whats the true story on getting the TPMS working.
By TPMS - I mean tire pressure monitoring system that displays the individual tyre pressures.
If anyone knows for sure, please let us know.
Also some latest EVIC numbers and their features would be great.
Thanks!
Thanks!
