elafilos
- Joined
- May 25, 2022
- Messages
- 32
- Reaction score
- 47
Hi guys,
As some of you might now I blew my engine in April. This engine has been overheated a couple of times in the past, being driven hard almost 220.000 km and eventually failed me.
Back in 2022 it had dropped a valve seat and decided to take it to a rather shady shop for inspection. Heads where surfaced and it was up and running after almost 3 months sitting inside that shop.
Since I found an engine replacement, I decided to take apart my old engine for science and figure out what went wrong. Being doing that the last couple of days and I have found some very interesting things. Since I have not taken apart this engine again I wanted to share some things with you and let me know what's normal and what's not.
What I have noticed is that 3 cylinders (passenger side) where filled with water. That's the first weird thing.
The second even weirder is that the head gaskets seem to me from another engine / block and don't fit right.
Third and even crazier is that I found this blocking a water passage way
Not the lighter, but this small pebble. It was aluminum, which made even less sense.
These are all my findings for now - I ll keep you posted on the process.
