OxLibertySport
I'm on my 2nd Liberty ... both bought at auction (salvage) . The first I repaired & sold off ... never had to change the oil. My current I decided to keep for a while (low mileage) & just finished it up. It's last oil change was in 2019, so I figured it was time.
Man is that oil filter in a tough spot when working from the ground! Manageable, but tough! I got through it all pretty easy with not too much mess ... until ... what should've been the simplest part. Adding oil! There's some sort of baffle in the oil filler neck!! ~ It was a windy day & I was using my standard high-volume funnel with a 5-qt jug of Castrol. Starting to pour, I was paying more attention to the wind blowing the oil than I was the filler neck ... before I knew it, the #@!* filler neck overfilled & put about a half quart or more down the side & on to the drive way! I was like ***!
I pulled that "baffle" out & continued the fill with no problems. What the heck is this part for??
