Flasher resistor mod
Heavymetalduck
Someone with a wrench and free time.
Ohio
I replaced all my turn signals and the first two LEDs caused hyperflash when I added anymore they just stayed on.
I didn't want to add resistors to every single led so I did this instead.
I'm followed some directions on another thread. I can't find it now but whoever made them your amazing.
I got lucky as the resistor just barely fits and I made sure nothing was touching.
Works well as I don't have hyperflash anymore.
The resistor I used
Edit:
The resistor used I used creates too much heat. I will reinstall a different resistor most likely 0.2 ohm.
Has anyone figured out how to eliminate hyperflashing in a KK without having to add individual resistors to all 4 turn signals?
Heavymetalduck
Ohio
Do the kk liberty's have the same type flasher module?
klc
“It flies like a truck.”
PNW
You might need the bulbs with built-in resistors, then.
Heavymetalduck
Ohio
Not sure why I can't edit my post but I replaced with the 1.8 ohm in the amazon link.
No longer heats up even after 10 mins.
