For the folks with after-market signal lights....
timmer
South Louisiana
thecause17 said:
I just got done sealing mine about a half hour ago...and I wanted to give a headsup of where to look for the leak(s). I thought at first it was going to be around the outer edge of the light, seemed to be the most likely spot...my leak was in the hole where the screw goes that holds the light in place. I filled the hole completely with clear rtv, then put a hole through it again so the screw could go through again later...hopefully it's all sealed up now. I'll check for leaks again before I put them back in.
Did RTV help in your instance?
My drivers side clear lens/housing gets moisture in it when I wash the libby, it doesn't happen naturally.
Also, is yours the left one too? I think I got mine from Revotec on eBay.
