Marlon_JB2
Kombat Edition Jeep
You're absolutely correct Marlon. You are not a fish. I'll put the blame squarely on my laptop's tiny keys and my fat fingers. Sorry.
Steve, I've got the OME790 (CRD springish springs). They fit like a glove. No mod to shock mounting plates, spring perches or isolators. They are a considerably heavier spring rate (500 (?) lbs) over the gasser (310lbs) and will certainly lift your KJ's chin up a bit.
Stock CRD front coils are 410lbs.If you put on 300lbs coils you will actually be lowering your KJ.Adding the OME 927's(400lbs) you will sag after a short time.You will however get a nice firm(not harsh) ride with the OME 790's if installing them on a CRD or very heavy gasser(ARB bumper and winch and full armor).Thanks Ian,
Are the OME 790 a direct replacement for the stock CRD springs then? i.e. Same spring rate? Or are they a harder rate than the stock CRD springs? I am just thinking a 500LB spring instead of just over 300LB spring will have my Jeep bouncing all over the road instead of compressing the spring! Hehe. And just to clarify, will any of the OME springs work with stock shock absorbers or will I have to replace the shock absorbers as well? (Trying to keep costs down) Thanks for your patience Guys. Steve :smokin:
1) From what I've read and seen, all the parts have been revised to keep the Jeep at the after lowered height. This was due to safety concerns after a single rollover on a 2002 2WD in a controversial type of test. As for how, I'm guessing they just lowered the spring stack by an inch or so.
2) With the mileage you are at, you are sagging at least 1" due to worn out springs.
3) As the final results do vary, I would look at the official "how high are you" thread http://www.jeepkj.com/forum/showthread.php?t=39094
Thanks osufan. Exactly the ansewrs I was looking for. I priced new OEM shi=ock?Springs and it's not much different than the OME?Blisten lift option. So I may just go ahead and lift it right away. Only problem is that it's getting a bit chilly up here, and my garage is small and unheated
I may have to put it off till next spring or have alocal shop do it.:disgust:
I'm working 10-12 hr days. And this saturday is the gun-deer opener here. Next two weekends after that I'll be out of town.
Still putting the recipe and prices together. Is JBA the best value for the parts?
Steve, considering the difference in spring rates between stock petrol and stock diesel, one can safely surmise that the stock CRD springs will boost the front end up. But then, anything must be an improvement over what you are currently riding on.
