joeysjeep
Thanks I just had a local junk yard call me saying that they got in an 03 liberty v6 4x4 and it has the drive shaft I go by this afternoon to pick it up. Is $100 a good price for a used front Drive shaft thanks guys
to answer your question, buy a stock one.
You can buy a replacement from Driveshaft & CV Joint Components as well.
Don't know what liberty you have so here are the links
JEEP Liberty 02-07 3.7L Auto
Jeep Front Driveshaft - 31,5"(52111597AA)
JEEP Liberty 02-07 3.7L Manual
JEEP Liberty 02-04 2.4L Auto
Jeep Front Driveshaft 29.3"
JEEP Liberty 04-06 2.8L Auto
Jeep Front Driveshaft - 32,5"
Ok so after I got the drive shaft back j one and all started to get under the jeep to install it and noticed it was the wrong dang shaft. The one I picked up had a cv joint on the side going to the front diff but a u joint going to the transfer case.
The KK driveshaft has a transfer case end u-joint from the factory, but the flange is square w/4 mounting bolts. Could be the flange on the transfer case was retrofitted on the one you got the shaft from to accept the newer style shaft.
