ktmrider
I installed a front DTT when I changed axles. I had it up on the rack and reached over and turned one of the front wheels and the other one turned the same direction. I thought the DTT would work like an open diff and the other wheel would turn the opposite direction. I have a DTT in the rear and that's what happens when you turn one wheel with it off the ground. I looked at the Eaton website and it is supposed to work like a open diff. I could have sworn I checked that after we installed the diff. There is no noise and the DTT works offroad. The only thing I noticed before was it pulled hard after the install but I swapped tires and that went away.
