still on my original repair done last Oct, from the kit, no problems
how often do you use 4x4?
not that it should cause it to break that soon and so many times
Your front driveshaft turns all the time,does not matter if your in 2wd or 4wd it still turns.This is August no need to use 4WD. And with the Comand-Trac in my KJ I dont understand why the boot is failing.
Most likely your issue is one created from heat.As alot of '03+ KJ's with the cat right next to the t-case end of the front driveshaft it will crack from heat,most take between 50k-150k before it's done.Aftermarket boots may not hold up as well to the extreme heat and will fail sooner.If it was me I would be making a small heat shield,would do wonders.
