Gear Pattern, Is it Good?
tyates007
I am finally getting around to installing my Eaton TT and 4.10 gears. I am getting very close on the pattern but would love someone to look at it for a second opinion, or third. I think I need to shim the pinion a little more to bring it closer to the ring gear. Backlash is at .007.
tyates007
This morning I pulled it all apart and added .010 to the shim stack on the pinion. First set of pictures is with Backlash at a tight .006 and second pattern is with .008
Something I recently learned, its just as important to look at the pinion gear itself. The pattern should be near the center of the teeth.
Im no expert, but it almost looks like it was too shallow then you went a bit too deep.
