GeekFisher
OK, did great work during the week-end and I'm almost "finished" with the project...
So I know pictures are appreciated so I took a few:
LED reverse backup light:
Phillips LED brakes and LED third brake light:
Sylvania Silverstar High beams:
Silvania Silverstar Low w/ Fogs on
CB installed on the passenger side, the unit is small enough that it won't be annoying for a passenger:
Roof rack, front view:
Roof rack, side view:
Roof rack, top view (caps missing, have yet to buy them)
Plastic looks bad but it's not as worse as it seems.
I finally reuse a Sportrack unit that I had from a previously owned car sitting in my dad's shed for three years. I think it looks great, almost like its OEM.
I plan on adding these safety caps:
I should receive hub caps tomorrow and both the USB flushmount and Bluetooth OBDII this week.
I also ordered 1200 lumens fog light bulbs and another third brake light light bulb, red this time as I'm not that pleased with the current bulb result.
I thought about reusing the bulb (came in pair, tossed the other one in the console) for map lights (168) but I don't want them to dim when I drive. If I only change these two bulbs and leave the rest of the interior with standard bulbs, will the LEDs dim ? Also, they might be too large to fit in there even if the connector is the right one. Last but not least, it seems to be a PITA (from what I read) to get to the bulbs ? Need advices/direction on that one.
Thanks,
Thanks,
