Good quality Driveshaft
WickedBruce
San Antonio TX
Where can I find them for the rear? I've done a few searches...even autozone said they can't get one for me. WTF. Figured since I have some vibes that I should do the U-joint...so may as well do the driveshaft at the same time too. I don't want crap quality though. I'll spend the extra dough!!
Find a local driveline shop and have it rebuild and re-balanced.I had a local shop rebuild a rear XJ driveshaft with a new CV end(double cardon joint),all new u-joints,and re-balanced for $150 using Spicer parts only.
Ask around where hotrods or the more extreme offroaders get there driveshafts done locally.If you think you'd get better quality by buying a driveshaft like one from Ton Woods your sorely mistaken as your just paying for a name when they use the same parts as good driveline shops use but charge more.
ridenby
Gold Supporter
Kentucky
Agree about tom woods , replaced my u-joints myself,no problem. Used greasable u-joints no prob in 15-20 thou. mile.
WickedBruce
San Antonio TX
I never even heard of tom woods stuff. lol. I have heard of the spicer...tried to do a search for them...but i guess you gotta call them. I'd rather buy new if i can..i'm kinda paranoid of getting things used or re-done. I have some pretty terrible luck
If you want new just drive down to the dealership and order one,might take awhile and will cost about $700.
You can also have a driveline shop make you a 100% new driveshaft,just take yours in and let then get the measurements and they can usually have it done in a day or 2 and should run about $200-$300.
WickedBruce
San Antonio TX
I might skip the dealership...doubt i'll ever go there again...at least not the closest one to me. They seem very uneducated. I'll check around here and see what i can find. Thanks tjkj
WickedBruce
San Antonio TX
Well now that i've got my alignment issues all straightened out...i've got some vibration coming from it
But more than likely thats just a ujoint that is worn out/ rusted up
I'd replace them not replace the whole driveshaft:shrug:
Luke
Interloper
Bancroft, Canada
Same results after my lift Bruce ... just got my u joints today. I'll keep ya posted but I think you may be going overboard with a whole new drive shaft :shrug:
