That is indeed the HD cooling shroud... BUT, thats the non-HD electric fan.
Im going to throw some more odd facts in the mix, thats most likely from a 2004 KJ. For whatever reason, ALL 2004 KJ's came with the bigger shroud like that. Didnt matter if it had the HD cooling package or not, it got that shroud. It really makes changing the oil filter suck.
My KJ is a 2004 and it came with the bigger shroud, two speed electric fan, and no mechanical fan. All I had to do was buy the Mopar fan blades and the clutch.
If rockauto ships up there, they have the fan blades and clutches. You may also be able to get the shroud and electric fan for cheaper?
The mopar fan blades have been out of stock for a bit, but it shows the part number if you want to search elsewhere. Im sure the Dorman unit would be fine:
Cooling System Parts and More for Your 2004 JEEP LIBERTY at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.
www.rockauto.com
Pretty sure I used the Hayden clutch. It seems to work perfect and doesnt roar all of the time.
www.rockauto.com
Here is the HD shroud (Mopar is out of stock) and the factory non-HD electric fan.
www.rockauto.com
The HD electric fan is listed in a different place:
www.rockauto.com
