gfunk_nz
I've just signed up and had a bit or a search through the forum, seems there's some pretty good info available.
I have a question about my 03 crd. A few months back I noticed the heater seemed to no longer be blowing really hot air. I'm not sure if it's an issue in the heater sytem as much as maybe a thermostat stuck open.
The engine temp gauge barely gets above about 1/4 I can't remember what it would get to prior to the lack of heating.
Reading through some of the info I see the viscous heater does a lot of the work in getting the heater to blow hot, if the thermostat is doing it's thing the the engine temp being around a 1/4 is correct, is there anything I can check on the viscous heater.
Any other suggestions?
