Height adjustment after LiftKit OME / JBA
jeeplib05
Ohio
Shocks don't provide lift height only the springs, so something is wrong with them
I would contact JBA and let them know
GunnerSchenck
This much I'm aware of.. I asked which shocks because if he's using shocks that were bad before lifting it, they probably won't provide much help for the springs.. and was thinking that perhaps given the right circumstances, his new springs have been worn down to the different heights.. the lowest being which the wheel with the shock that was the worst, therefore has worn on the new spring the most..
Mostly was just checking to see if he put new shocks on with the springs, though I'm aware many don't and their springs typically don't sag that quickly.. especially within 15k km.
Just figured if he's convinced the shocks were right in the first place but still bad shocks.. that maybe he'd replace the shocks, and get new springs again to go with.. and this time, be 250% positive they're the correct ones.
Either way.. yeah, new springs are in order here.
pivert
France
I uses OME shocks :
Front : OME2926 Spring with 90009 shock
Rear : OME2948 Spring with 60069 shock
pivert
France
I'm sorry, error of copy/past....
I'm uses OME shocks :
Front : OME2927 Spring with 90009 shock
How to check the references of the springs? With a label? An engraving ?
springs should have a tag on them
pivert
France
I will check this reference on springs during the replacement of isolators springs because the isolators from JBA are very bad quality (CROWN model).
pivert
France
I confirms that following references used :
927 and 948
Checked on springs
Envoyé de mon iPhone en utilisant Tapatalk
KJ604
Vancouver BC
This sounds similar to me.
My rear end is fine. both sides sit 22" even w/ 948 and one extra iso per side.
But my front end has 927 with .25 strut spacer and .375 clevis spacer.
The passenger side sits at 22 and 1/8" which is low from what it should be with all those parts, I was expecting 3.5"
And the driver side sits at 21.5 which is like there is no extra spacers on there at all.
I thought something was wrong with the spring and got them replaces by ARB under warranty. Got the same results. And when I took the first set of springs out they are still the exact same height. All springs had 927 tag.
Im still lost over this one and have no time to fix anything. Still running around on stock wheels.......
krisP
NY/PA
driver side usually sits lower. I have ironman lift and with one extra isolator in the rear it sits at 23.5 on both sides. The front driver side i have 3 ring clevis and passenger side 2 ring clevis. DS sits at23" and PS is 23 1/4 "
Myke
USA
Check your clevis to lca bushing.
Sent from my SM-N910V using Tapatalk
