Hello question regarding liberty
Timsav623
New york
Hello everyone, hope all is well today..or atleast better than my day haha.
So the guy i bought my 2003 Jeep liberty 3.7L from had delt with a cracked head by putting some sort of quick seal into the coolant system.. therefore it clogged the system up so i did a major flush (heater core heavily). Any who, i then replaced my thermostat due to no heat and over heating in the first place. Nowww i have no overheating, but my heat will come on very hot and within maybe 1 minute itll turn room temperature (if that).. now keep in mind i also replaced all hoses in the entire system as well.. so PLEASE somebody help.
More than likely still clogged heater core , that stuff is bad.
renegade 04
Albany New York
Sounds like a heater core, when you put that stuff in the cooling system you need to disconnect the coolant lines from the heater core and run a bypass.
Timsav623
New york
yeah i actually flushed the entire heater core as welll, i put this flush system that you cut the heater core hoses and it gets in own little hose insert..i flushed the whole thing..you still think that its just really really clogged?
