sandersfamily541
- Joined
- Dec 10, 2024
- Messages
- 7
- Reaction score
- 1
I'm doing a motor swap 2005 Jeep Liberty Shell pulled motor from an 07 dropped ****** and transfer case bolted it all together then stabbed it back in. Now I'm trying to use the intake manifold and throttle off of the original 05 since it's cable driven will that work with the 07 motor? And I'm also trying use the 05 wiring loom that's hooks up to the manifold. Is this going to work? Do I need to change the ECU for the newer motor?
Basically need to know what all electrical I need to change over. Please thank you. I have 6 days to get this done and vehicle out of my driveway or I get evicted so any help is appreciated thank you
