well the 245 75s are on
no rubbing at all
pinch welds are not modified
I SHOULD HAVE GONE WITH 265 75'S!!!!!
tires look small with the fender gap!
which 245/75's?
style and brand will make all the difference
like I said an '03 with OME coils all around and the day I put the coils on
I also put on 245/75 Goodyear MTR's
perfect fit ,close but no rub
unless you count the rear at very full stuff
That being said I know that the springs were sagging after 3 years and 30K miles so after 8 years and how ever many miles the coils on your rig are done and probably about 1" lower than the day thy were put on the Jeep
so to say no rub with 245/75 I can believe
to say you should have gone 265/75 because the smaller tires do not rub
I say BS ,unless you want it to rub or you are trying to tell us that your KJ is different than the rest and did not sag and can fit larger tires than every one else which could very well be the case
