I purchased a class 3 hitch today and attempted to install it. I just wanted to verify the bolt size and pitch. The hitch came with M12 - 1.75 x 40mm. The bolts do not want to thread in. They will if I force them but I don't want to crossthread the holes. The jeep is an '02 and there is a lot of surface rust but they should still go. I sprayed so PB blaster in to break up the rust but to no avail. I have a tap that I can use to clean the holes out but I want to make sure I have the right thread pitch first.
Secondly, the hitch I bought only has 2 mounting holes on either side as oppposed to the 3 holes that the drawtights generally have. It is a Putnam brand. I would think that having less mounting holes would lessen the capacity of the hitch but it says 5000lbs. I will never tow anything near that but it would be nice to know I could without the hitch ripping off.
I am new to the whole 4x4 and towing scene so any information that you guys have would be greatly appreciated. Thanks!!
