Chad S
- Joined
- Jan 29, 2020
- Messages
- 32
- Reaction score
- 6
I was looking for 3" 3/8 self-tapping bolts, but I can't find any. Would anyone happen to have a link, please?
Like I said it can be a pain, especially with fat fingers, that's why I like the smaller 1/4 in hardware. I doubt I used stainless on mine, not as much of a rusty belt here, but doesn't seem like a bad ideaI don't see a way to put a nut on the bottom. The spring perch is on top of the axle.
There’s a slot between the perch and the axle where you can slide the nut and hold it with a wrench.I don't see a way to put a nut on the bottom. The spring perch is on top of the axle.
LOL yes it is on top of the axle, but there is more than enough room to put a nut on the bolt, I put a lock washer plus nut on most of the ones I do.I don't see a way to put a nut on the bottom. The spring perch is on top of the axle.
I would try that, remove one then jack up or flex out to just make sure shock is not completely compressedI went with the 731s in the back and Im getting 31s (265/70r16) put on. So from what you did to your 03, I should probably remove one puck.
