Ry' N Jen
- Joined
- Dec 26, 2006
- Messages
- 9,242
- Reaction score
- 13
How many times must we tell people that Jeep Liberty's use
front SHOCKS and not struts!
I consider it a strut assembly a shock is a single object. A strut is a shock enclosed in a spring. Wrong?
a shock is a single-purpose unit... it's only job is to dampen suspension movement. you can take a shock out and still drive the vehicle technically.
a strut actually locates some critical component of the suspension or drivetrain as well as provides damping for suspension movement. it generally has a spring perch with associated spring and top hat, frequently has a bearing up top to allow rotation when used up front, connects to and locates the knuckle. if you remove a strut you cannot drive the vehicle since you've now removed a critical component.
Easy way to seperate a coilover and strut is....................a shock is a single-purpose unit... it's only job is to dampen suspension movement. you can take a shock out and still drive the vehicle technically.
Tommudd. Ever thought of learning how to think before you speak? Maybe learning how to rephrase things before you post might make you seem like less of a dick. As I always appreciate learning new things and being corrected when Im wrong and your simple minded excuse for that did that.... Maybe just maybe you should try a little bit more of a subtle way to explain that.
