HOW TO: Determine what errors a check engine light represent
2003renegade
South Beloit, IL
ok i got a p0442 code. checked the gas cap. that cant be it. what else could it be? the engine light is so bright! its driving me insane
P0442=EVAP system - small leak detected. First check your gas cap to make sure it is screwed on tight and making a good seal. If you think it is bad get a new one. That is probably it....most likely cause.
paco29toy
Baja- San Diego
Anyone knows where the Coolant temparature sensor goes?
quick8
ny
i got P0037 oxygen sensor?its the one after the cat on the drivers side?anyone know the mopar part number?
t_bois
colorado springs,co
Your gas cap has a rubber seal. I had to replace mine due to the rubber seal having a (visual) crack, but I still had to have the computer reset to clear the code.
JeepyJez
UK
Autel TP100 Indicates Error Code P0069
Hi Guys
Can anyone shed light on the meaning of error code P0069? Have referenced earlier posts in this thread but #0069 doesn't seem to be covered.
Engine Management light illuminated and sporadic 'limp mode' cut-in. Seems to occur at low speed start/stop type driving.
Thanks in advance.
