how to drain fuel
KingKJ
The Rock Spotter
Utah
What is the best way to get the fuel out of my liberty? My liberty decided to die on a full tank of gas so I need to try to get the fuel out of the tank, so far my best idea has been to just cut a fuel line and let it drain out by turning the key to on and sitting there letting the fuel pump do its thing, Is there any other way I could drain the fuel or any spot in particular that would be ideal to cut the fuel line?
At least on the KK there are places where you can disconnect the fuel line and not have to cut it. I like the idea of having your fuel pump do the work. Unless the reason it died was a dead fuel pump. :p
That will do it but it's a bit brutal, fixing the Jeep would be another option?
