HOW TO: Install an EVIC or OTIS (overhead computer)
nightowl90028
Fredericksburg, Va
well..i removed the dome light and i dont have a bracket..i read thru this post and i see you guys give good details but its strung out thru 10 pages..and i get sorta confused if i dont have the bracket underneath the dome light im ok right..and after i get my evic can you somehow tell me my next step then ill follow the directions from the other site i think it was blakbox.com or something..thanks for the help
Boilermaker
I don't remember my install being that much different than the page linked in the first post. The only difference for those with '05 or later was having to get that bracket but not needing to install a temp sensor. Almost anything you need to know about the bracket (unfortunately the pics of the bracket are gone) is in posts 20 and 22 in this thread by thx1138.
nightowl90028
Fredericksburg, Va
Thanks for the reply..i thought the harness plugs into the evic or otis and then the wires run down the a-pillar and connect into the fuse panel. or do i have it turned the wrong way. i think im going with a Evic since the features are better. all i really wanted was MPG and DTE so maybe Otis will be cheaper and easier since those are the only two features my main concern was the way to install the harness..Thanks again for the help:)
Atrus
Metro Detroit, MI
Just curious to know - has anyone completed this on an '07? I think they changed some things on the '07 (such as no throttle cable), and I am curious to know if anything changed on the BCM as well.
From what I am reading, for the temp to work I'll need an '04 or later EVIC from a Dakota or Liberty, right?
Sorry, I know, seems like the same question over and over. I am just really interested to see if the '07's still work. FWIW, the '07's still come with the temp sensor installed - at least mine with a 9/06 build date does.
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
It'll work. It's not like they changed the Bus or anything. Even though the KJ has had its changes over the years, none of them have been really huge to the point where workarounds can't be done. Get an EVIC for an '04 or later and be done with it. I recommend the EVIC instead of the Dakota's OTIS... installing an OTIS just isn't worth it, lol.
04Liberty
MD
My wife's 04 came with it already installed.
StarDreamers.us
Anywhere I want to
Added an 03 GC unit to my 05 Sport. Everything works except the temp sensor. Tried the 03 temp sensor no luck. Then tried an 05 temp sensor. Did not work. Any ideas? Thanks!
Atrus
Metro Detroit, MI
StarDreamers - the temp gauge will not work and never will. I'm not an expert on why, but I think the BUS system is different.
If you want the temp readout to work on a 2004+ KJ, you need a 2004+ EVIC.
Marlon_JB2
Kombat Edition Jeep
The BUS is the same. The way the message is delivered to the EVIC is different. :p
JeepINgeek
Silver Supporter
For Twain In Diana
Of Course I didnt get the pigtail with mine!
Ok, I have connectors with sufficient GA wire that will fit the pins.
What i need to know ( and couldn't tell from the provided images) what pins go to what.
IE 1 = Ground 2= Data etc...
The Evic is out of an 04 and going into an 06.
Any help is appreciated! Thanks Guys.
Uffe
Hi guys.
I'm new to the forum here. I just wanted to add some info to this good thread on EVICs.
I did this guide on LOST: http://www.lostkjs.com/forum/phpBB2/viewtopic.php?t=27605
concerning EVIC installation.
I have an 03 so maybe the sensor stuff is not affecting me - but I am puzzled why it would be suddenly changed. My temp sensor works fine.
JeepINgeek
Silver Supporter
For Twain In Diana
Ok i got it plugged in tonight. ( didnt install it because 06's dont have the mounting bracket under the headliner)
Everything worked wonderfully except for the temp lol. Its a 04 module in a 06 libby. It said --F. ive read elsewhere that it will work eventually ( after some temp changes) all i did was drive around the block. Ill post the pinout i used later.
chrispitude
I have a 2006 KJ and thanks to this thread, I realize I need the plastic mounting bracket. I'll call the dealer and get it ordered.
pictures here!
Does anyone have any tips on getting the bracket into the headliner cavity, and on gluing/attaching and centering it properly?
Great information in this thread, keep it up!
- Chris
tdamocles
Oley, PA
Just performed EVIC install.
These directions were great and if you follow it exactly you will not have a problem. I used the floppy drive connector as the evic module connector. You have to grind it on one side to get it to install easier. Also the floppy drive pin holes must be slotted(with a tiny screwdiver) so the connector can slide onto the evic contacts. Also, remove the wires from the floppy drive connector and squeeze the the contacts together oh so slightly. This will make it a tight fit when installed on the evic. If you don't, you may have the evic turn off when installed because the contacts disengage from the evic when pressure is applied to the wire . One more thing, I got an evic from a 2005 Liberty for my 2004 Liberty with sunroof controls - the sunroof switch is different. No need to worry because the switch clips in to the housing and is easy to remove. I used an utiility knife when cutting the headliner (make sure you have a nice blade and watch that you don't cut any of the existing wires.)
chrispitude
Hi all,
I have also completed my EVIC install. You can find pictures here:
my EVIC installation pictures
Informative comments are given for each picture. The pictures can also be made larger to see more detail. I couldn't have done it without this thread!
- Chris
Atrus
Metro Detroit, MI
What's so special about the EVIC anyway.
MPG, Miles left per tank, easier to program functions, Compass, Outside Temp if you can get the right year (I didn't), Some have TPMS.
Is it worth several hundred dollars? Not in my opinion. Is it worth the $20 I spent on the EVIC, Bracket, and Pigtail? Without a doubt, IMO.
