HOW TO: JET Performance Chip
Diggerfreek
Colorado
STEP 1: Buy JET Chip
STEP 2: Remove NEGATIVE battery terminal. (size 10 socket)
STEP 3: Locate and Disconnect ALL plugs attached to the ECU.
STEP 4: Plug in the JET Chip. It can only go into 1 socket (3rd from the left) Make sure you firmly but carefully push the chip in all the way.
STEP 5: Plug back in ALL the ECU harnesses.
STEP 6: Re-attach the negative battery terminal.
STEP 7: MOST IMPORTANT ... Install your JET Performance Sticker!!!
STEP 8: Take a step back ... and enjoy!!!
SETexasLibby
Pearland,TX
what else do you need installed before installing the chip? In other words, what does it require?
Idaho08KK
Idaho
x3. I have been considering one of these, since I now get about 10 mpg around town in my KK, 14-15 mpg on the highway. Damn gas guzzling 3.7L!!:mad:
jnaut
Seattle
How are you only getting 14-15 on the highway in a 2008?
Idaho08KK
Idaho
I don't know. Larger tires, and an unaerodynamic brick I guess. I don't have a lead foot by any means, but after 100 miles of in town driving, I use half a tank. 130-140 miles highway at 70 mph, half a tank.:confused::confused:
jnaut
Seattle
Hmm, does the KK get that much worse mileage? Anyone else follow their average? Your tire size doesn't seem extreme? I could understand if you had 200,000 miles on it and bad plugs, but you seem to be someone who maintains and knows how to maintain your vehicle. Plus it's only 2 years old.
That's just ugly.
With the skids and everything, do you know what your curbweight is?
SETexasLibby
Pearland,TX
I have an 2008 that just got 19.92 mpg last tank. I know it's stock but wow I commute 42 miles one way. Then again Houston is flat. I'm getting 320ish miles and that gets me till about a little under a quarter tank. I still want to install a CAI and maybe ponder chipping it before a possible lift and oversized tires
Idaho08KK
Idaho
No idea what the curb weight is.
I bought it 10 months ago, and only have 4,521 miles on it now. I am going on a trip tomorrow, and decided to fill up after work today. I went 103 miles, all in town driving, and from the last fill up, it took 9.3 gallons. I got approx. 11 miles per gallon.
I will be driving approx. 120-130 miles tomorrow, all freeway, so I'll post my results when I fill up again tomorrow.
jnaut
Seattle
Man alive. You're not putting premium in it, right? The 3.7 calls for regular, and according to the FSM may suffer performance if you put premium in it.
jnaut
Seattle
Jeezopeat, dude, now I feel bad for ya. I mean, I got one gas tank with just under 14 once and I nearly had a heart attack. It was during the time when my ignition switch went out and was in the shop. Don't know if the guys in the shop idled it for a long time or what. But I've never seen anything below 14. My overall trend is slightly down over the last year. I'm attributing that to the aging vehicle. But generally, I'm high 15's to mid 16's in city, and on a long roadtrip I can hit just over 20.
03Liberty/BC
performance chip
does the jet performance chip really work? is it Bs. like a lot of the stuff out there
Idaho08KK
Idaho
Well, I just filled up again after taking a couple of trips. I drove 227 miles, 90% of that freeway at 70mph, and I used 13.9 gallons of fuel. I averaged 16.33 mpg this time, with almost all freeway driving.
mag03kj
LOST
thats shit dude...hell i get 15-16 in town thats with brush guard,hitch,homemade light bar!
Idaho08KK
Idaho
My dad laughs at me about it. He has a 2007 Ram 1500 with a 5.7L hemi, and gets better mileage than me.:mad:
The only factors that I can figure that attribute to such bad mileage are the tires, and added accessories. The tires are 245/75R16, Load range E, and are very heavy. They are much heavier than the stock tires. They are a 10 ply tire, with 6 ply sidewall.
Also the added weight of the skid plates, tow hooks, and front grille guard didn't help.
I may try the Jet just to see if I get an increase in mileage. 2-3 mpg more would be awesome for me.
