NJallDAY
Theres a ton of options when it comes to roof rack cross bars. The most expensive being factory or name brand systems such as thule. Another rout is the simple 2x4 and u bolts, serves its purpose but an eye sore imo. Below is a quick write up for a low profile, strong, and aesthetically pleasing set of cross bars. they produce very little wind noise and i havent seen any significant reduction in mpg. Im writing this after the fact so i dont have as many detailed pictures as i would like.
What youll need:
TOOLS
*hack saw, sawzall really anything that can cut metal
*tape measure
* a couple wrenches or adjustable to keep it simple
MATERIALS
*1 3/8" chain link fence top rail (comes in 10' sections) or equivalent tubing
*4 T clamps (i got mine from an awing installer for $6 each)
* Paint of your choice
step one:
Take your tape measure and take measurement at the front end of your side rails and measure inside to inside. now take a measurement at the rear section Make sure you take both measurements as the rear section isnt as wide as the front
FRONT about 40 3/4
Rear about 38 3/4
Step two
Break out your hack saw or what ever you will be using to cut and lay down your first measurement. Take a 1/2 inch off the number for some wiggle room and remember measure twice cut once. now cut your piece and do the same with your second measurement also removing a 1/2 inch from the number.
Step three
now that your pipes are cut take your clamps and fit them onto your pipes and mock them up to your side rails.
Heres where things get a bit tricky, you may need to bend your tubing to prevent them from resting on your roof. i know someone who used the same method and had no problem. Myself on the other hand had to bend them. I tried it on my own but couldnt get them to budge. so i brought them to my local meineke and they bent them for free. Any shop with a tubing bender should do it for free if you catch them in a good mood. Its a very subtle bend maybe a half inch past straight.
step four if everything fits good go ahead and paint or plasti dip everything. All the material should be galvanized steel so you wont have any issues with rust. a good idea is to get some rubber pipe insulation and wrap the bars with that and some zip ties. (pool noodles work good too).
step five after your paint dries or how ever you decided to finish them, position them on your side rails in the desired position and tighten everything up. and now you have set of strong cheap and good looking cross bars! I had 20 2x4's strapped on and they didnt flex at all.
Hope someone finds this useful
What youll need:
TOOLS
*tape measure
MATERIALS
step one:
FRONT about 40 3/4
Rear about 38 3/4
Step two
Step three
