hollysprings
- Joined
- Feb 18, 2009
- Messages
- 16
- Reaction score
- 0
On the rolling thing, for every car I've ever had or heard of, being engaged in any gear with the ignition off means that the engine and wheels are directly linked, i.e., the engine must turn for the wheels to turn. Since there is internal resistance, this tends to keep the car from moving on slight inclines. Which gear you are in determines how much resistance there is at the wheels. In other words, a lower gear requires a larger engine movement for a one-foot change on the outer circumference of the wheels. I'm pretty sure (but not certain) that the resistance is the same regardless of direction. Thus, since R is usually geared lower than 1, the greatest resistance would be in R whether you are facing uphill or down. The difference is small and since 1 is easier to shift into, I usually put a manual into 1 when applying the E-brake.
However, with today's irritatingly-dumb "smart" cars, there is no reason why they have to work like this. There might be a logic circuit which disengages all gearing when the ignition is turned off. That would seem pretty dumb to me, but I wouldn't put it past them.
I'm curious if that is the case - please post back your conclusion. How steep is the incline where you are still seeing movement when in-gear? Have you tried parking on level ground, engaging R or 1, and pushing the jeep by hand? Does it feel exactly the same as pushing it by hand with it in N?
