I'm feeling a little bit better so I added some more lights!
BjBnet
Ottawa, Ontario, Canada
you skeeeered of the dark? Is Hongcouver north enough for that 6 months night/ 6 months day thing? Just trying to figure the logic....
Dear Americans, WE (Canehdians) are not all like Ryan, he is a special case! hahaha
Seriously though Ryan, looks good!
iamweasel
Joburg, South Africa
LEDs are the way forward :)
I plan to add two pods to my lightbar with 3 10w LEDs each. 6000 lumens from only 60watts...
Should probably do all four while I'm at it :icon_twisted:
iamweasel
Yes!
Me as well!
I'm sure the prices will drop in a year or two...
Right now $1500.00+ is a bit too steep for me!
If you have the inclination to make one yourself, there's no reason to spend anywhere near that much. My planned build will cost about a tenth of that and be as bright as a set of HIDs.
Check out Deal Extreme for all the components you need.
I'll post a how-to thread soon when I make mine
iMTB
JPOTM WINNER
Tampa
2 ipfs and highbeams
You should just get a couple ipfs or lightforces
iMTB
JPOTM WINNER
Tampa
lightforces on, headlights off
I think with also a winch, something more serious & reliable in this department would be very beneficial.
40892[/ATTACH]"]
bmrrwolfe
North Olmsted, OH
If you build one please make a write-up!
I love the look of LEDs, and not to mention less power needed.
Ry' N Jen
Don't worry, the wiring harnesses will use either all Hella or Bosch relays...
4 30 amp relays.
1 relay per 2 lamps, plus a 20 amp fuse.
16 gauge wire.
I have literally wired 100's of sets of off road/rally car light setups over the last 30
years...
I wish I could find a photo of my green mini's engine compartment.
It uses one 30 amp relay per lamp. The lamps are Bosch 225 (almost 9 inches) with
130 watt bulb.
The head lamps each run a 2 40 amp relay's and 130/100 watt H4's
980 watts total.
Automotive wiring is my main hobby.
No such thing as over kill when it comes to wiring.
I'm going to be getting Hella 4000i's later this year...
Ry' N Jen
Thanks for posting that link!
I will be looking very closely at all the goodies they sell!
Looks like I too will be fabricating my own LED light bar(s)
soon!
That site is gonna keep me awake all night!
iamweasel
Sure thing!
Deal Extreme have a redonculous amount of stuff. free postage too
Just ordered:
10x 10w LED
1x 100W power supply
1x 200w inverter
oh and some optics from a local supplier. I'm considering a mix of beam angles: mostly 12 deg with some 30 deg
Each set of 5 will be mounted on a computer CPU heatsink
Should be good for 10 000 lumens from the two new lights:)
Not the ideal power supply I'd like to use (alternator power through inverter to 220v through transformer to 36v 3A), but getting 36 "clean" volts at a constant current isn't easy. Not unless building a DC-DC Buck/Boost driver is something you consider easy. But this way I do have an inverter which will prob come in handy
Will take a few weeks to get here (SA postage is God awful), so I'll do a write up in a month or so hopefully
G36 Shooter
michigan
WTF! Does it get that dark up there in BC? Nice set-up, nothing like carrying your day light with you.
Xodius
Las Vegas, NV
Lmfao, yeah...you need help. Come to think of it...I am going to use you to show my wife 4 100w lights are not nuts lol. Thanks man. :)
LibertyFever
New Brunswick, Canada
I haven't read all the replies (I'm too lazy) but if you upgrade the alternator don't you have to program the ECU to let it know it's there? After all the ECU controls the alternator.
According to what Ryan was told by dealer, the new Rene alt simply bolts and plugs in... and voilla more wattage in la cottage!
Drillbit
indiana
haha I feel sorry for the idiots coming at you that refuse to turn off their brights!
