trichard310
Im replacing my rear shocks with RSX. I noticed there is a little play in the top shock bolt, do I need to use some washer in there or just bolt it down?
Dont know if I did this right.
So what you putting struts on? The KJ only uses shocks on all 4 corners.noice. that's helpful information when I pick my struts up.
thank ya sir!
I do believe it's called a coil-over shock when there is an upper-control arm and a strut if there isn't an upper-control arm... Not much of a difference in my opinion...
