Inc
Free
- Joined
- Jan 12, 2009
- Messages
- 355
- Reaction score
- 0
Here is the Jeep stock, then Frankenlifted
Parts list for the SFA:
1. Front HP D30 out of an XJ, Solid Diff Cover, JKS control arm skids, 4.88's, Aussie Locker, Warn 5x4.5 Hub Kit, Warn inner and outer Chromo Shafts and the WJ knuckle/brake/steering conversion w/ chevy 3/4 ton TRE's and heavy duty 1.25x.219 drilled and tapped tie rod and drag link = $850
2. Rubicon Express Extended Steel Braided Brake Lines = $50 (do not buy these, they do not work and I am currently looking for a final solution)
3. Fox 2.0 Coil Over Shocks = $207 each (2) Fox-980-99-004-A
4. QA1 2.5id 10” #250 upper springs = $37 each (2)
5. QA1 2.5id 10” #300 lower springs = $37 each (2)
6. OME 864 Rear Springs = $75
7. Edelbrock #63914 Xtreme Travle IAS Medium Valving Rear Shocks = $35.95 each (2)
8. 35x12.5x15 Goodyear MT/R Kevlar = $196.60 ea. (4)
9. Rear 8.25 - 4.88 gears = $250
10. Rubicon Express Sway Bar Disconnects and TJ Sway Bar = $40
11. Front Drive Shaft = $275
12. Rear Drive Shaft = $375
13. Ford Steering Box = $90
14. Custom Exhaust = $400
15. Rubicon Express Long Arm Kit = $1,200
16. Long Arm and Coilover mounting = $350
17. Rubicon Express Extreme Duty Front Track Bar = $130
18. Yukon Alloy Axle Shafts for the Chrysler 8.25 = $250
