TheBlueKJ
He is now running the same as I am
In his signature says he's running monroe's? Thought they were just as good as stock, but if I'm wrong I can get them at a discount from pepboys woooo:signs1:
Monroe Sensa Trac Load Adjusting Shock for the rear
501 and I are running them on KJs , Marlon is running them on a KK
and some others.
We just installed 501s this weekend
501 has the Ironman front shocks of course
I have the Rancho RSX 17505s yet
I believe hes running Monroe coilovers in the rear from a Dakota. I don't believe he uses Monroes in the front. If I wrong I'm sure he will chime in. I run Bilstiens in the front and did run Monroe coilovers in the rear but but over heated them from running them to hard and to light in the rear. After I get a new rear bumper I will run them again.
Alright, I'll have to look into them. Definately gonna run the ironman front shocks still.
Marlin is having Ironman make extended length shocks for the rear as well. Not sure when they are going to be here but those will be an option as well
If you look over on LOST in the Ohio section you'll see pics of 501s with his right after the install
What do you mean they overheated from running them too hard and too light?
Here's what mine looks like after last weekends M&G:
Front Ironman coils & Shocks
Rear Ironman coils & Monroe Shocks
Sitting at 22 3/4" FD, 23" FP, 23" RP, 23" RD
Chris, Me, Mudd
How heavy's your rear? Porkchop said since his was too light the shocks were run too light and they warped when he went to the dunes.
Nothing special but I put the Monroes on to see if they will help when I pull my trailer. I use it starting in April through late October, so hopefully they will work out. If not I'll have to change them.
That's what I figured since you recommended them to me. You've never steered me wrong before.You won't have any issues, nothing different than any other shock :headbang:
clevis ring is a 2 inch conduit nut found in hardware stores here in the UShello !
i'm new in world of jeep so where i can find 3/8 ring clevis
and the lift kit iron man how many inch give to libberty because i want 3inch
Don't need them just an easy way to make sure you are the same height on both sides
How much lift from the Ironman from 2 inches on up to 3.5 depending on how you sit it up
ALL lift kits coming out of Australia are advertised at 1.5 inches
We all know that you get more than that but due to regulations over there that is what we get here ( advertised height)
I didn't use the CRD or HDs on 501s
Bumpstops ,....every inch of lift should have an inch of bumpstops
although when we set them up they are more like 3-3.5 inches but 2 inches of bumpstops works well
But for example with over 4 inches of lift
I'm running 3 inches of bumpstops in the rear of mine due to tire size/ wheel width/ etc
