It has started!! Rocker sliders!!
the factory weather stripping around the 3rd brake light is weak sauce.
Add your own closed cell weather stripping. Anything is better than the factory.
kejobe
NE Ohio
It's already gone. Has a little larger than a quarter size hole where the left screw goes in. Was leaking water inside so I removed the light and ran a bead of clear silicone around it just to stop the leak.
Also there's a good amount of rust under the left molding behind the left roof rail right where the roof curves down in the back.
Next years project.
I still need to replace the radiator, rear axle seals and bearings, and brakes all around for this winter.
kejobe
NE Ohio
I finally remembered to get pics of the roof rust that'll be next years project.
This is actually worse than it looks. Not much rust on the visible outside but completely gone under the light.
