JBA extended swaybar end links
rbm92226
Anna, Texas
I sent a quick email off to JBA for marlins thoughts. I'm kinda thinking the extended braided lines will be ultimately the best solution. At least I get another small upgrade :-/
the_dealer
Macon, Ga
I've been thinking about getting the braided ones as well. My stock hoses are looking a little sketchy
rbm92226
Anna, Texas
Asking for an opinion from those of you that know way more than me. I've decided to get the longer braided lines from JBA to solve my clearance issue. Should I go with the lines for 2.5", or 4.0" lift. I want to be able to safely route the lines so that there is no contact with any of the front end components. It appears I can do it with the 2.5, but would 4 be better? Currently I am sitting at 22.5" drivers front, 22.75" passenger front, and 21.75" d/p rear. Any thoughts or input would be appreciated.
the_dealer
Macon, Ga
I'd find out the lengths of both, and measure stock length and compare. If they are too long, what I always do is pick up a pair of springs from the hardware aisle at lowes. Around 1/4" diameter and an inch or 2 in length. Zip tie one end to your hose, and the other end to your shock, spring, uca, hole in fender or wherever. The hose is kept off the tire and away from other moving parts, but extends when your suspension droops. I can shoot u a pic if u want
the_dealer
Macon, Ga
Hope this helps
wheeee32
Not the mountains.
I have my links in hand. Just got back from Key West for work so obviously haven't installed them. Friday I'll throw them on.
wheeee32
Not the mountains.
Well it got pushed to this Saturday. Storm is rolling through Friday. I'll let ya know how it goes after I've got them on.
rbm92226
Anna, Texas
Wheeee32 did you get yours installed yet?
rbm92226
Anna, Texas
I'm just hoping to find out if he has the same brake line clearance issues? I'm on the fence about paying 180.00 for the longer brake lines or just sending them back to jba.
wheeee32
Not the mountains.
USPS failed me. I should have had it yesterday but nooooooooo. So I won't get them till Monday and I'm stuck at work all day on Monday and won't get to install them for another week and a half. I hate work-ups.:mad3::emotions122:
the_dealer
Macon, Ga
Just bend the hard line, not a big deal
Luke
Interloper
Bancroft, Canada
I had to bend mine after the Frankenlift install ... to stop them from being pinched... not much though.
I'm not sure how much adjustment he needs so I was hesitant to suggest it.
the_dealer
Macon, Ga
It's one of those use your best judgment type adjusments...don't get all crazy with it and you'll be fine
rbm92226
Anna, Texas
I would have to bend the line enough to get about an inch of clearance. If you look at the picture from a earlier post the link is dead center on that line. I'm not sure I trust bending a 9yr old brake line that much. The flex braided lines are awesome, but not in the budget this month:-(, damn kids and their college tuition
the_dealer
Macon, Ga
It will be fine, I've re-directed alot sketchier looking ones. You can bend in more than one spot so you are tweaking too much on one area. BTW, I'm thankful I have awhile before the kids go off to college. Although it sneaks up fairly quickly
