Jeep Liberty 2004 limited full dot fluid replacement
so I need help
I don't know how much dot fluid she takes she really needs it done like the fluid is black
Get two of those small brake fluid bottles, maybe three. Extract what you can from the master cylinder with a turkey baster. Then bleed the system until it is coming out clear at the calipers on all 4 wheels. If you have the time to wait, a gravity bleed should work fine. Keep the master cylinder topped off or air will be introduced and you’ll have to start bleeding the system over.
My KJ Uses regular DOT3 fluid, and no where do I see mention of the brake fluid spec at master cylinder.
Is that the case with the KK as well?
Deb'nKJ
Why would anyone buy less than a litre/quart?
Still bemused by all these refs. to DOT3, which I think might be available from a few classic car specialists here, but DOT 4's been the standard for at least 30 or 40, possibly even 50. years.
Deb'nKJ
Well I never knew that but, as I said DOT 3 was phased out here probably in the 60's (come to think of it) with the widespread adoption of disc brakes, so that sort of makes sense now.
As I recall, you had to use the fluid for your make of brakes, either Girling (which was amber) or Lockheed (red) but then came universal fluid, which was clear & branded by oil companies, which I suspect was the original DOT 4.
As for changing brake fluid, that, in my experience, is an American thing, not something I've ever done - or known anyone else do; in fact I was brought up to conserve the stuff - I suppose because fluid was so expensive.
I've changed it on a few cars, it absorbs water and muck, it often comes out almost black. I used 2 Ltr to fully flush my KJ.
Shankster
Durango, Colorado
Be aware that the "DOT" referenced here is US Department of Transportation. I believe it's used internationally but ISO (class 3, 4, 5, 5.1) is a different standard but is very similar and basically equivalent to DOT 3, 4, 5, 5.1. I haven't lived in the UK since 1986 so don't know what is on the shelves over there and which designation is used. I just mention this because it could explain the DOT 3 (or ISO 3??) availability in the UK.
Deb'nKJ
I know it's hygroscopic (although I'd been working on cars for a long time before I learned that) but as most years you'd probably have to do something that meant having to bleed the brakes, I suppose the problem never really arose (even being careful not to lose any more than was absolutely necessary)
Deb'nKJ
I'm familiar with the acronym, by which I've referred to brake fluid all my life (well, since my last couple of years at school) & I would've said DOT 3 disappeared long before '86.
Out of curiosity, just had a look at what was available & of the 1st 60 listed on eBay there were 2 lots of DOT 5, one DOT 5.1 & one DOT 3, curiously, I thought, synthetic - & 50% more expensive than same brand's DOT 4. ISO was never mentioned, nor did seem to appear on the labels on the containers.
