Jeep on column ignition assembly- not including key tumbler.
cruisingram2000
I see some threads kinda bounce around this issue. I went out to start my liberty- nada to the starter. So after a quick test of the starter, started into the ignition issue. Looks like the piece the key tumbler/cylinder attaches too is bust up. Worn out. I have a parts Liberty, so I am trying to pull the part from there- but no one makes this assembly new to buy huh? Seems like a common problem with these liberties? I am way out in the outer islands of Hawaii, so parts aren't easy to come by!
DadOSix
Cumberland, MD.
Post in thread 'Another No Crank No Start'
https://www.jeepkj.com/threads/another-no-crank-no-start.80576/post-810149
Dorman 924-704 will get you rolling again.
I am not generally a fan of Dorman parts, but i have used this in the past. If you have an Advance Auto, Auto Zone, O’Reilly, etc, it should be easy to source.
Helpful hint - if you are an amazon fanatic, Advance will price match for you. Have to do it online and buy it online, but saves about 20 bucks.
Good luck and Mahalo!
cruisingram2000
Thanks for all this guys- but that part number is not for my year no? Never mind- it does look liike my year
