John P.
Hey guys, I finally got a full day off to really go through the 2011 Jeep Liberty I purchased. So at 103K here is everything that I have on my to-do list per thorough inspection. 1. Flush and replace coolant 2. New Spark Plugs 3. Change oil and filter to Mobile 1 or Royal Purple with wix filter. 4. Replace Shocks all around. 5 Change transmission fluid and filter.
The A/C system seems to be having an issue as well. I have not got my full gauge kit with me but it was acting like it was low on freon so I stopped off and bought a quick fill with a cheap gauge to give it a bump. Well upon hooking up the gauge it showed that it was overcharged, ambient temperature of 90 degrees and showing 55psig compressor running. So I presumed that the high pressure switch was shutting off the compressor, it did sound labored. but as I was about to disconnect it due to not needing freon the gauge fluctuated and dropped down to about 43 and the compressor stayed running then a short time the pressure started building up to over 55 and the compressor shut off. I do have the extended warranty that covers the A/C system's major parts. Would I be correct in diagnosing this as a faulty expansion valve when I tell the shop what is going on with it? Initial symptoms were cold air at speeds other than idle, then when at idle stopped no cold air. Yes it would be great if I had my real gauges. Sorry for the lack of helpful data.
Also, if there are some other maintenance things I missed on my list, please suggest them to me, I already replaced the air filter with a K&N drop in filter today. I plan on keeping this Liberty for quite some time so the K&N saves me money in the long run.
