kj auto lockers
MARINEMP
PA
So im planning on installing the no slip auto locker in the rear any one use one.im just worried about it being a pain to drive on the road. Also for the front I cant afford and am not willing.to put on demand lockers up there can I put like a LSD dif up there if so where can i get one ? The only reason I done want to lock my front with a auto locker is because I live in the snowbelt rate below Erie pa and I use my 4wd fairly often and have been told its not safe to lock the front in wintery conditions
ridenby
Gold Supporter
Kentucky
Used an Aussie,it worked. Easy install,as are all the lunchbox lockers. Use 80-140 gear lube.
ridenby
Gold Supporter
Kentucky
Open front,never got a round toit. Yes,Aussie is loud at times. If you want quiet,smooth,go LSD rear. Front too,if you think you really need it.
