KJBart
- Joined
- Feb 20, 2024
- Messages
- 12
- Reaction score
- 25
Recently bought a '07 Sport w/6spd manual and a 3" lift kit installed. Currently has 31x10.50R15 mud tires on. Here's the issue I'm consternating on.
When I put it into 4x4 Hi or Lo and then accelerate a bit hard, I get a light to medium (knocking?) noise coming from the front half of the truck.
(see video)
Some notes:
Only happens in 4x4, either Hi or Lo
Other than the noise, 4x4 seems to work normally
Shifts into 4Hi or Lo without issue
Doesn't happen in reverse while in 4x4
Doesn't make any noises while turning
Have to push it a little to make it happen
Previous owner (a mechanic) replaced the following with new parts before selling, both lower control arms, front drive shaft, both front CV axles, front wheel bearings, upper ball joints, rear u joints, left outer tie rod.
Any thoughts on what the noise could be? Was thinking maybe where the front shaft mounts to the transfer case but the shaft is new. I'm not a mechanic so any help to narrow it down would be appreciated.
(see video)
Some notes:
