67Customs
Well, some oily waxes will look hazy and streaky if you apply it to thickly. Basically, if you add a heavy coat, the whole application doesn't have time to dry before you remove it.this was JUST after the waxing,, and rewaxing got rid of most of it.. maybe i just need to keep waxing til it goes away..
keep in mind that ive had the jeep maybe 2.5 years and id never doen anything to it but run it through a mikes wash.
no wax, no buffing, nothing.
The thing to do will be to add lighter coats of wax. One reason why the second coat was better is because when you wax over wax, it is slicker that the first application so you added less.
Try giving the streaks an hour to set and then try to remove them with a quick detailer.
