Lift faq: Read before asking questions!
nmadd118
LI, NY
here are some pics i took today after washing her yesterday
Abby922
Douglasville
Best tires,wheels and lift kits
Im new to this forum thing but im looking to lift my 05 jeep liberty sport and ive heard that OME lifts are really good but im also looking to get bigger wheels and tires. With and OME lift whats the biggest size tire i coulld put on my jeep WITH the lift?
new jeep owner
New Brunswick Canada
did some searching , found this post by another member.
lot's of knowledge on here, just gotta take the time to search and read
by the way, you said you were new. welcome aboard
With a 2.5" lift you can fit 245-75-16" tires.
265-75-16's will fit with 4+ inches of lift.
explained many times
but with OME lift and a couple of additions you can fit 245-75s real easy
265-75-16s requires more lift, regearing etc
So OME 927s front 948 rears OME shocks teraflex front bumpstops , hockey pucks rear bumpstops 245-75 on stock wheels good to go
ALSO JBA has the Ironman lift now with free shipping
Ironman kit with clevis lift in front and again 245-75-16s
Ironman lift rides real well
WickedBruce
San Antonio TX
So would you recommend the frankenlift 2 or the ironman now? Looks like you have to get each part separately on JeepinBA for a total amount of about $640?
Yes but Frankenlift comes with everything preassembled with special spacers etc
OME/ Ironman comes unassembled
so different ways to lift
The clevis is just moving the shock higher in the clevis by 3/8 of an inch
and the top plate you don't have to install but it does give you 1/2 inch more lift if you so desire
So 927s in front , clevis lift and top plate will put the front at 22.50-22.75 middle of the wheel to bottom of the flare
without the clevis and top plate you will be 1.25 inches lower at 21.25-21.50
With the Iron man and a top plate you can be at 21.75
now on to the rear.....................
I think all of this is on the forum somewhere :shrug:LOL
WickedBruce
San Antonio TX
Yea I realize it's all in here...I'm just pretty new to this and I like to have a direct up-to-date answer, haha.
I see what you mean now about the clevis. Doesnt that ever slip?
Well it looks like my best bet is just to save up and get the franky then. And if i read it right, i wont need rear iso to lvl it out, because the rear is already higher?
with the frankenlift you should also install two upper isolators as well in the rear to level it out
hard to say, depends on what shop rates are in your area and how much time they think it would take
If getting the Franky is a fairly quick job to do, BUT if they have never done one they may drag it out some
Here we knock them out in 3 hours or so, Frankys a little quicker
TwoBobsKJ
Northern Ohio
Most get 2" conduit nuts from Home Depot or someplace like that & put them on the bottom of the shock - more to get accurate spacing than anything else. If the clevis bolt is torqued to spec it won't slip - but conduit nuts give you peace of mind.
Cardhu
Great White North
Ironman additions
Shocks:
Front:
12711GR
Rear:
12712GR - Standard Length not Extended like 132L or 702A's
Coils:
Spring rates not known at this time.
Front:
JEEP014B 0 - 50KG Add Weight
JEEP014C 50 - 100KG Add Weight
Rear:
Jeep015B 0- 200 KG Add Weight
Trim Packer for more effective spring rate by compressing coils (Not more lift) fits under spring pad and on top of strut flange.
3 Sizes of 5, 10, 15mm depending upon load requirements, varies by spring.
Other info:
Part number additions for Bilstein
24-139168 = BE5-D916-H0
33-185859 = BE5-A702-H0
Any Rear shocks to fit 2003 Dakota Quad Cab 4x4 will work for Extended Length set ups.
jggv98
Monterrey
I didn't find this question
I just order the following configuration for the rear suspension:
OME 948 springs
OME N132 shocks
Lower and upper coils springs isolator for each side
Can I use both isolator (lower & upper) with this shock or I should have requested the N132L long shock?
Thanks
OME 948 springs
OME N132 shocks
Thanks
Should of ordered the 132Ls for the rear, 132s are stock length and will top out
Also should of bought 4 upper isos for the rear, 2 extra on each side if adding clevis etc to the front, since you don't mention the front hard to say what you will need.
Also bumpstops??
