Liberty02sport
Got a call from the stealership today saying that in addition to the faulty driver circuit for cyl. #5 in the PCM (replaced PCM). That when they started it back up they noticed a ticking in the engine so ran a compression check and found cyl. #6 was @0. Proceeded to pull the valve cover and found that #6 had a seized lifter and had tossed the rocker arm :evil: .
The engine was just replaced with a brand new long block at 88,296mi. when a valve spring broke and dropped a valve into the cylinder. Are the 3.7L really this big of a POS ?? seems this engine can't go more than a few thousand miles before developing major engine trouble. What gives ???????
ETA: new engine still under warranty from LKQ so we'll see how this goes...
UPDATE: Engine #3 on it's way.
